LLDP build with application recipies supported
531件の閲覧回数
ranga_yn
Hello NXP,
we wanted to make the LX2160 LLDP build with below added application , could you help for recipes and version supported.
docker
docker-compose
mongodb
elasticsearch db
タグ(3)
487件の閲覧回数
yipingwang
Not sure which version LLDP are you using now.
In your Yocto build environment, please run the following command.
bitbake <pkg_name> -c patch -f
You will get which recipe is used in the build environment from the console log.
