KW45B41Z83 Fuse Read
Lu888
 I use this API to read fuse index = 0x20 ,but return is kStatus_NBOOT_Fail(0x5a5aa5a5U),I want to know why this is happening,and the parameter-->systemClockFrequencyMHz how to set up?Before use this API,I have already used nboot_context_init this API.
Ricardo_Zamora
Hope you are doing well. The main purpose of these APIs is to provide access to functions used and implemented in ROM to authenticate the application image and processing sb3 files.
For this, it is recommended to some of these resources:
So, depending on what you are trying to do, I would recommend you check any of these Application Notes.
Hope this helps.
Ricardo
