KW45B41Z83 Fuse Program
Lu888
When I use this API,i want to know how to  regulate the voltage for over-drive and how to set up
systemClockFrequencyMHz?
Ricardo_Zamora
Hope you are doing well. The main purpose of these APIs is to provide access to functions used and implemented in ROM to authenticate the application image and processing sb3 files.
For this, it is recommended to some of these resources:
So, depending on what you are trying to do, I would recommend you check any of these Application Notes.
Hope this helps.
Ricardo
