Imx8 AAOS14 Window Manager issue
VarunK1
Hello
I have flashed AAOS 14 on to iMX 8 QM MEK board. I am facing issue with screen resolution (window sizes). By default screen size is coming 1024x600. I require a screen size of 1920x1080.
I am attaching some screenshots for your reference. Kindly, let me know where can do changes in the AAOS 14 source code to change the screen sizes.
Bio_TICFSL
To change the resolution in MX8
connect to the device's command line or use a developer tool like ADB.
Use the command adb shell wm size to view the current physical screen size.
To change the resolution temporarily, use the command wm size <width>x<height> (e.g., wm size 1280x720).
To revert to the default resolution, use the command wm size reset.
To change the default resolution persistently, you may need to modify the bootargs, which is a more advanced process detailed in the device's user guide.
%3CLINGO-SUB%20id%3D%22lingo-sub-2183557%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EImx8%20AAOS14%20Window%20Manager%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183557%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%3CBR%20%2F%3E%3CBR%20%2F%3EI%20have%20flashed%20AAOS%2014%20on%20to%20iMX%208%20QM%20MEK%20board.%20I%20am%20facing%20issue%20with%20screen%20resolution%20(window%20sizes).%20By%20default%20screen%20size%20is%20coming%26nbsp%3B%3CSTRONG%3E1024x600.%20%3C%2FSTRONG%3EI%20require%20a%20screen%20size%20of%20%3CSTRONG%3E1920x1080.%3CBR%20%2F%3E%3C%2FSTRONG%3EI%20am%20attaching%20some%20screenshots%20for%20your%20reference.%20Kindly%2C%20let%20me%20know%20where%20can%20do%20changes%20in%20the%20AAOS%2014%20source%20code%20to%20change%20the%20screen%20sizes.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184947%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Imx8%20AAOS14%20Window%20Manager%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184947%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-huuid%3D%226376125696772109455%22%3ETo%20change%20the%20resolution%20in%20MX8%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-huuid%3D%226376125696772109455%22%3Econnect%20to%20the%20device's%20command%20line%20or%20use%20a%20developer%20tool%20like%20ADB.%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-huuid%3D%226376125696772109065%22%3EUse%20the%20command%20%3CCODE%20class%3D%22mv6bHd%22%3Eadb%20shell%20wm%20size%3C%2FCODE%3E%20to%20view%20the%20current%20physical%20screen%20size.%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%224caec2cd-53c8-49df-b137-21bc7e80706f%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%224caec2cd-53c8-49df-b137-21bc7e80706f%22%20data-uuids%3D%226376125696772109065%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CC4QAQ%22%20data-ved%3D%222ahUKEwjp_4L6tqGQAxUGKkQIHZDGKeQQ3fYKegQILhAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%3CSPAN%20data-huuid%3D%226376125696772108675%22%3ETo%20change%20the%20resolution%20temporarily%2C%20use%20the%20command%20%3CCODE%20class%3D%22mv6bHd%22%3Ewm%20size%20%3CWIDTH%3Ex%3CHEIGHT%3E%3C%2FHEIGHT%3E%3C%2FWIDTH%3E%3C%2FCODE%3E%20(e.g.%2C%20%3CCODE%20class%3D%22mv6bHd%22%3Ewm%20size%201280x720%3C%2FCODE%3E).%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%222f65bfc2-5e35-47d5-92fd-12e52dc9952c%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%222f65bfc2-5e35-47d5-92fd-12e52dc9952c%22%20data-uuids%3D%226376125696772108675%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CDcQAQ%22%20data-ved%3D%222ahUKEwjp_4L6tqGQAxUGKkQIHZDGKeQQ3fYKegQINxAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%3CSPAN%20data-huuid%3D%226376125696772112381%22%3ETo%20revert%20to%20the%20default%20resolution%2C%20use%20the%20command%20%3CCODE%20class%3D%22mv6bHd%22%3Ewm%20size%20reset%3C%2FCODE%3E.%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%22971f1373-3b75-481f-88b3-bd1e75581fd7%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%22971f1373-3b75-481f-88b3-bd1e75581fd7%22%20data-uuids%3D%226376125696772112381%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CC0QAQ%22%20data-ved%3D%222ahUKEwjp_4L6tqGQAxUGKkQIHZDGKeQQ3fYKegQILRAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%3CSPAN%20data-huuid%3D%226376125696772111991%22%3ETo%20change%20the%20default%20resolution%20persistently%2C%20you%20may%20need%20to%20modify%20the%20bootargs%2C%20which%20is%20a%20more%20advanced%20process%20detailed%20in%20the%20device's%20user%20guide.%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%220b798293-6870-4a90-a7e1-db8c01949f96%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%220b798293-6870-4a90-a7e1-db8c01949f96%22%20data-uuids%3D%226376125696772111991%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CDAQAQ%22%20data-ved%3D%222ahUKEwjp_4L6tqGQAxUGKkQIHZDGKeQQ3fYKegQIMBAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22niO4u%22%3ERegards%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
