IMX8MP SD CARD Detection issue
880件の閲覧回数
Rajendersamangula
 i was testing the SD2 Interface in  imx8mp custome board, we added the schematic as below attached image  and we configured the below dts in board dts related . as per the EVK Operation the board is switching between 3.3v to 1.8v operation during data transfer.
Here i used below switch power VSD_3V3 Insted of NVCC_SD2 FOR Testing but issue is same
[32m[ 100.362225] [0m[33mmmc1: [0mnew high speed SDHC card at address aaaa
[32m[ 100.385895] [0m[33mmmcblk1: [0mmmc1:aaaa SC16G 14.8 GiB
[32m[ 100.564120] [0m[33mblk_print_req_error: [0m[1m26 callbacks suppressed[0m
[32m[ 100.564134] [0m[31mI/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2[0m
[32m[ 100.580241] [0m[31mI/O error, dev mmcblk1, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2[0m
[32m[ 100.591337] [0m[31mI/O error, dev mmcblk1, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2[0m
[32m[ 100.602404] [0m[31mI/O error, dev mmcblk1, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2[0m
[32m[ 100.613143] [0m[31mI/O error, dev mmcblk1, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2[0m
[32m[ 100.624228] [0m[31mI/O error, dev mmcblk1, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2[0m
[32m[ 100.635931] [0m[31mBuffer I/O error on dev mmcblk1, logical block 0, async page read[0m
[32m[ 100.646682] [0m[31mI/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2[0m
[32m[ 100.657404] [0m[31mI/O error, dev mmcblk1, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2[0m
[32m[ 100.668140] [0m[31mI/O error, dev mmcblk1, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2[0m
[32m[ 100.678885] [0m[31mI/O error, dev mmcblk1, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2[0m
[32m[ 100.690432] [0m[31mBuffer I/O error on dev mmcblk1, logical block 0, async page read[0m
[32m[ 100.697621] [0m[33m mmcblk1: [0munable to read partition table
[32m[ 100.902422] [0m[31mBuffer I/O error on dev mmcblk1, logical block 0, async page read[0m
[32m[ 132.961163] [0m[33mblk_print_req_error: [0m[1m14 callbacks suppressed[0m
[32m[ 132.961176] [0m[31mI/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 2[0m
[32m[ 132.977620] [0m[31mI/O error, dev mmcblk1, sector 1 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 2[0m
[32m[ 132.988707] [0m[31mI/O error, dev mmcblk1, sector 2 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 2[0m
[32m[ 133.000141] [0m[31mI/O error, dev mmcblk1, sector 3 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 2[0m
[32m[ 133.011574] [0m[31mI/O error, dev mmcblk1, sector 4 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 2[0m
[32m[ 133.022661] [0m[31mI/O error, dev mmcblk1, sector 5 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 2[0m
[32m[ 133.047531] [0m[31mI/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2[0m
[32m[ 133.056334] [0m[31mI/O error, dev mmcblk1, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2[0m
[32m[ 133.067411] [0m[31mI/O error, dev mmcblk1, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2[0m
[32m[ 133.078414] [0m[31mI/O error, dev mmcblk1, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2[0m
[32m[ 133.089985] [0m[31mBuffer I/O error on dev mmcblk1, logical block 0, async page read[0m
[32m[ 133.102686] [0m[31mBuffer I/O error on dev mmcblk1, logical block 0, async page read[0m
[32m[ 133.113104] [0m[31mBuffer I/O error on dev mmcblk1, logical block 0, async page read[0m
[32m[ 133.124708] [0m[31mBuffer I/O error on dev mmcblk1, logical block 0, async page read[0m
[32m[ 133.135332] [0m[31mBuffer I/O error on dev mmcblk1, logical block 0, async page read[0m
[32m[ 133.147595] [0m[31mBuffer I/O error on dev mmcblk1, logical block 0, async page read[0m
[32m[ 133.159816] [0m[31mBuffer I/O error on dev mmcblk1, logical block 0, async page read[0m
[32m[ 133.172050] [0m[31mBuffer I/O error on dev mmcblk1, logical block 0, async page read[0m
[32m[ 133.184274] [0m[31mBuffer I/O error on dev mmcblk1, logical block 0, async page read[0m
[32m[ 133.376775] [0m[31mBuffer I/O error on dev mmcblk1, logical block 0, async page read[0m
[32m[ 133.425479] [0m[33m mmcblk1: [0munable to read partition table
what i need here is i need my sd card to work in 3v3 level. iam able to get the detection of sd card but it is not readable.
my configuration of dts
&usdhc2 {
assigned-clocks = <&clk IMX8MP_CLK_USDHC2>;
assigned-clock-rates = <100000000>;
pinctrl-names = "default", "state_100mhz", "state_200mhz";
pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>;
pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>;
pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>;
cd-gpios = <&gpio2 12 GPIO_ACTIVE_LOW>;
vmmc-supply = <&reg_usdhc2_vmmc>;
bus-width = <4>;
no-1-8-v;
max-frequency = <25000000>;
status = "okay";
final output:
imx8mpevk login:
imx8mpevk login:
imx8mpevk login: root
7[r[999;999H[6n8root@imx8mpevk:~# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
mmcblk2 179:0 0 7.3G 0 disk
|-mmcblk2p1 179:1 0 83.2M 0 part /run/media/boot-mmcblk2p1
`-mmcblk2p2 179:2 0 6.5G 0 part /
mmcblk2boot0 179:32 0 4M 1 disk
mmcblk2boot1 179:64 0 4M 1 disk
mmcblk1 179:96 0 29.7G 0 disk
NXP i.MX Release Distro 6.1-mickledore imx8mpevk ttymxc1
imx8mpevk login:
imx8mpevk login:
root@imx8mpevk:~#
root@imx8mpevk:~#
root@imx8mpevk:~#
root@imx8mpevk:~#
root@imx8mpevk:~#
root@imx8mpevk:~#
root@imx8mpevk:~# [ 53.204996] mmc1: card aaaa removed
[ 54.494632] mmc1: host does not support reading read-only switch, assuming write-enable
[ 54.507807] mmc1: new high speed SDHC card at address aaaa
[ 54.514138] mmcblk1: mmc1:aaaa SC32G 29.7 GiB
[ 54.579534] blk_print_req_error: 8 callbacks suppressed
[ 54.579543] I/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 54.595988] I/O error, dev mmcblk1, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 54.607164] I/O error, dev mmcblk1, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 54.619385] Buffer I/O error on dev mmcblk1, logical block 0, async page read
[ 54.630133] I/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 54.641276] I/O error, dev mmcblk1, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 54.652768] I/O error, dev mmcblk1, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 54.666656] Buffer I/O error on dev mmcblk1, logical block 0, async page read
[ 54.673827] mmcblk1: unable to read partition table
[ 54.743395] I/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2
[ 54.754949] I/O error, dev mmcblk1, sector 1 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2
[ 54.766631] I/O error, dev mmcblk1, sector 2 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2
[ 54.780512] I/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 54.791210] Buffer I/O error on dev mmcblk1, logical block 0, async page read
[ 57.764836] mmc1: card aaaa removed
[ 61.159580] kauditd_printk_skb: 8 callbacks suppressed
[ 61.159590] audit: type=1334 audit(1776550758.196:16): prog-id=10 op=UNLOAD
[ 61.171847] audit: type=1334 audit(1776550758.196:17): prog-id=9 op=UNLOAD
[ 65.070760] mmc1: host does not support reading read-only switch, assuming write-enable
[ 65.084575] mmc1: new high speed SDHC card at address aaaa
[ 65.102862] mmcblk1: mmc1:aaaa SC32G 29.7 GiB
[ 65.171885] blk_print_req_error: 2 callbacks suppressed
[ 65.171896] I/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 65.188475] I/O error, dev mmcblk1, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 65.199891] I/O error, dev mmcblk1, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 65.212268] Buffer I/O error on dev mmcblk1, logical block 0, async page read
[ 65.223329] I/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 65.234610] I/O error, dev mmcblk1, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 65.245811] I/O error, dev mmcblk1, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 65.258065] Buffer I/O error on dev mmcblk1, logical block 0, async page read
[ 65.265245] mmcblk1: unable to read partition table
[ 65.339512] I/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2
[ 65.351038] I/O error, dev mmcblk1, sector 1 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2
[ 65.362544] I/O error, dev mmcblk1, sector 2 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2
[ 65.376346] I/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 65.389118] Buffer I/O error on dev mmcblk1, logical block 0, async page read
kindly help me on this
thanks
2 返答(返信)
762件の閲覧回数
Manuel_Salas
Hello @Rajendersamangula
Hope you are doing very well.
It seems that the handshake at low-speed is working, but not at high-speed.
Have you tried populating resistors R54 and R55?
From your schematics it seems those are DNP.
Also, please try decreasing the frequency in your device tree.
Finally, you can try to increase the drive strength in your pinctrl_usdhc2 and enable the internal pull-ups in the lines you have not external ones.
If possible, measure the NVCC_SD2 line to ensure it is 3.3V.
Salas.
629件の閲覧回数
Rajendersamangula
Thanks for your reply manuel , i have followed the same. i am happy to share i found the solution with below changes, i have used a sd card breakout board with dataline pullups and i have used the sd card VSD_3V3 switch output from the PMIC insted of nvcc-sd2 .In dts i have updated my speed to 25 MHz from 100 mhz and with no-1-8-v.
%3CLINGO-SUB%20id%3D%22lingo-sub-2364185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MP%20SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E6%A4%9C%E5%87%BA%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2364185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eimx8mp%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7SD2%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%B7%BB%E4%BB%98%E7%94%BB%E5%83%8F%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89dts%E9%96%A2%E9%80%A3%E3%81%A7%E4%BB%A5%E4%B8%8B%E3%81%AEdts%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82EVK%E3%81%AE%E5%8B%95%E4%BD%9C%E4%BB%95%E6%A7%98%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E8%BB%A2%E9%80%81%E4%B8%AD%E3%81%AF%E5%9F%BA%E6%9D%BF%E3%81%AE%E9%9B%BB%E5%9C%A7%E3%81%8C3.3V%E3%81%A81.8V%E3%81%AE%E9%96%93%E3%81%A7%E5%88%87%E3%82%8A%E6%9B%BF%E3%82%8F%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rajendersamangula_0-1778591439927.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rajendersamangula_0-1778591439927.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rajendersamangula_0-1778591439927.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rajendersamangula_0-1778591439927.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F385144iA27BA3B36352C5A8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Rajendersamangula_0-1778591439927.png%22%20alt%3D%22Rajendersamangula_0-1778591439927.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rajendersamangula_1-1778591470174.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rajendersamangula_1-1778591470174.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rajendersamangula_1-1778591470174.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rajendersamangula_1-1778591470174.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F385145iB548CAD2B25A555F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Rajendersamangula_1-1778591470174.png%22%20alt%3D%22Rajendersamangula_1-1778591470174.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%83%86%E3%82%B9%E3%83%88%E3%81%AE%E3%81%9F%E3%82%81%E3%81%ABNVCC_SD2%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%ABVSD_3V3%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E9%9B%BB%E6%BA%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%5B32m%5B%20100.362225%5D%20%5B0m%5B33mmmc1%3A%20%5B0m%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20aaaa%20%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E9%AB%98%E9%80%9F%20SDHC%20%E3%82%AB%E3%83%BC%E3%83%89%3CBR%20%2F%3E%5B32m%5B%20100.385895%5D%20%5B0m%5B33mmmcblk1%3A%20%5B0mmmc1%3Aaaaa%20SC16G%2014.8%20GiB%3CBR%20%2F%3E%20%5B32m%5B%20100.564120%5D%20%5B0m%5B33mblk_print_req_error%3A%20%5B0m%5B1m26%20%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%8C%E6%8A%91%E5%88%B6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20100.564134%5D%20%5B0m%5B31mI%2FO%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC0%E3%80%81%E6%93%8D%E4%BD%9C0x0%3A(READ)%E3%80%81%E3%83%95%E3%83%A9%E3%82%B00x0%E3%80%81%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%881%E3%80%81%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B92%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20100.580241%5D%20%5B0m%5B31mI%2FO%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC1%E6%93%8D%E4%BD%9C0x0%EF%BC%9A%EF%BC%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%EF%BC%89%E3%83%95%E3%83%A9%E3%82%B00x0%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%881%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B92%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20100.591337%5D%20%5B0m%5B31mI%2FO%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC2%E6%93%8D%E4%BD%9C0x0%EF%BC%9A%EF%BC%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%EF%BC%89%E3%83%95%E3%83%A9%E3%82%B00x0%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%881%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B92%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20100.602404%5D%20%5B0m%5B31mI%2FO%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC3%E6%93%8D%E4%BD%9C0x0%EF%BC%9A%EF%BC%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%EF%BC%89%E3%83%95%E3%83%A9%E3%82%B00x0%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%881%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B92%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20100.613143%5D%20%5B0m%5B31mI%2FO%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC4%E6%93%8D%E4%BD%9C0x0%EF%BC%9A%EF%BC%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%EF%BC%89%E3%83%95%E3%83%A9%E3%82%B00x0%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%881%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B92%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20100.624228%5D%20%5B0m%5B31mI%2FO%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC5%20op%200x0%3A(READ)%20%E3%83%95%E3%83%A9%E3%82%B0%200x0%20phys_seg%201%20prio%20class%202%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20100.635931%5D%20%5B0m%5B31m%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E8%AB%96%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%200%E3%80%81%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%83%9A%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20100.646682%5D%20%5B0m%5B31mI%2FO%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC0%E3%80%81%E6%93%8D%E4%BD%9C0x0%3A(READ)%E3%80%81%E3%83%95%E3%83%A9%E3%82%B00x0%E3%80%81%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%881%E3%80%81%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B92%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20100.657404%5D%20%5B0m%5B31mI%2FO%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC1%E6%93%8D%E4%BD%9C0x0%EF%BC%9A%EF%BC%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%EF%BC%89%E3%83%95%E3%83%A9%E3%82%B00x0%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%881%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B92%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20100.668140%5D%20%5B0m%5B31mI%2FO%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC2%E6%93%8D%E4%BD%9C0x0%EF%BC%9A%EF%BC%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%EF%BC%89%E3%83%95%E3%83%A9%E3%82%B00x0%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%881%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B92%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20100.678885%5D%20%5B0m%5B31mI%2FO%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC3%E6%93%8D%E4%BD%9C0x0%EF%BC%9A%EF%BC%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%EF%BC%89%E3%83%95%E3%83%A9%E3%82%B00x0%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%881%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B92%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20100.690432%5D%20%5B0m%5B31m%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E8%AB%96%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%200%E3%80%81%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%83%9A%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20100.697621%5D%20%5B0m%5B33m%20mmcblk1%3A%20%5B0%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B32m%5B%20100.902422%5D%20%5B0m%5B31m%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E8%AB%96%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%200%E3%80%81%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%83%9A%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20132.961163%5D%20%5B0m%5B33mblk_print_req_error%3A%20%5B0m%5B1m14%20%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%8C%E6%8A%91%E5%88%B6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20132.961176%5D%20%5B0m%5B31mI%2FO%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC0%E3%80%81%E6%93%8D%E4%BD%9C0x0%3A(READ)%E3%80%81%E3%83%95%E3%83%A9%E3%82%B00x80700%E3%80%81%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%884%E3%80%81%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B92%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20132.977620%5D%20%5B0m%5B31mI%2FO%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC1%E6%93%8D%E4%BD%9C0x0%3A(READ)%E3%83%95%E3%83%A9%E3%82%B00x80700%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%884%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B92%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20132.988707%5D%20%5B0m%5B31mI%2FO%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC2%E6%93%8D%E4%BD%9C0x0%3A(READ)%E3%83%95%E3%83%A9%E3%82%B00x80700%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%884%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B92%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20133.000141%5D%20%5B0m%5B31mI%2FO%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC3%E6%93%8D%E4%BD%9C0x0%3A(READ)%E3%83%95%E3%83%A9%E3%82%B00x80700%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%884%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B92%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20133.011574%5D%20%5B0m%5B31mI%2FO%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC4%E6%93%8D%E4%BD%9C0x0%3A(READ)%E3%83%95%E3%83%A9%E3%82%B00x80700%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%884%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B92%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20133.022661%5D%20%5B0m%5B31mI%2FO%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC5%20op%200x0%3A(READ)%20%E3%83%95%E3%83%A9%E3%82%B0%200x80700%20phys_seg%204%20prio%20class%202%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20133.047531%5D%20%5B0m%5B31mI%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%200%20op%200x0%3A(READ)%20%E3%83%95%E3%83%A9%E3%82%B0%200x0%20phys_seg%201%20prio%20%E3%82%AF%E3%83%A9%E3%82%B9%202%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20133.056334%5D%20%5B0m%5B31mI%2FO%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC1%E6%93%8D%E4%BD%9C0x0%EF%BC%9A%EF%BC%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%EF%BC%89%E3%83%95%E3%83%A9%E3%82%B00x0%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%881%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B92%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20133.067411%5D%20%5B0m%5B31mI%2FO%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC2%E6%93%8D%E4%BD%9C0x0%EF%BC%9A%EF%BC%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%EF%BC%89%E3%83%95%E3%83%A9%E3%82%B00x0%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%881%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B92%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20133.078414%5D%20%5B0m%5B31mI%2FO%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC3%E6%93%8D%E4%BD%9C0x0%EF%BC%9A%EF%BC%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%EF%BC%89%E3%83%95%E3%83%A9%E3%82%B00x0%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%881%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B92%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20133.089985%5D%20%5B0m%5B31m%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E8%AB%96%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%200%E3%80%81%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%83%9A%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20133.102686%5D%20%5B0m%5B31m%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E8%AB%96%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%200%E3%80%81%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%83%9A%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20133.113104%5D%20%5B0m%5B31m%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E8%AB%96%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%200%E3%80%81%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%83%9A%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20133.124708%5D%20%5B0m%5B31m%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E8%AB%96%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%200%E3%80%81%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%83%9A%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20133.135332%5D%20%5B0m%5B31m%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E8%AB%96%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%200%E3%80%81%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%83%9A%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20133.147595%5D%20%5B0m%5B31m%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E8%AB%96%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%200%E3%80%81%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%83%9A%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20133.159816%5D%20%5B0m%5B31m%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E8%AB%96%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%200%E3%80%81%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%83%9A%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20133.172050%5D%20%5B0m%5B31m%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E8%AB%96%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%200%E3%80%81%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%83%9A%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20133.184274%5D%20%5B0m%5B31m%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E8%AB%96%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%200%E3%80%81%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%83%9A%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20133.376775%5D%20%5B0m%5B31m%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E8%AB%96%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%200%E3%80%81%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%83%9A%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%5B0m%3CBR%20%2F%3E%20%5B32m%5B%20133.425479%5D%20%5B0m%5B33m%20mmcblk1%3A%20%5B0%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E7%A7%81%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8C3%E5%AF%BE3%E3%81%AE%E3%83%AC%E3%83%99%E3%83%AB%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AF%E8%AA%8D%E8%AD%98%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AEdts%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%3CSPAN%3E%26amp%3Busdhc2%20%7B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_USDHC2%26gt%3B%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AC%E3%83%BC%E3%83%88%20%3D%20%26lt%3B100000000%26gt%3B%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CSPAN%3Epinctrl-names%20%3D%20%22default%22%2C%20%22state_100mhz%22%2C%20%22state_200mhz%22%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3Epinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc2%26gt%3B%2C%20%26lt%3B%26amp%3Bpinctrl_usdhc2_gpio%26gt%3B%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3Epinctrl-1%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc2_100mhz%26gt%3B%2C%20%26lt%3B%26amp%3Bpinctrl_usdhc2_gpio%26gt%3B%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3Epinctrl-2%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc2_200mhz%26gt%3B%2C%20%26lt%3B%26amp%3Bpinctrl_usdhc2_gpio%26gt%3B%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CSPAN%3Ecd-gpios%20%3D%20%26lt%3B%26amp%3Bgpio2%2012%20GPIO_ACTIVE_LOW%26gt%3B%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3Evmmc-suppl%20%3D%20%26lt%3B%26amp%3Breg_usdhc2_vmmc%26gt%3B%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%90%E3%82%B9%E5%B9%85%20%3D%20%26lt%3B4%26gt%3B%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CSPAN%3Eno-1-8-v%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E6%9C%80%E5%A4%A7%E5%91%A8%E6%B3%A2%E6%95%B0%20%3D%20%26lt%3B25000000%26gt%3B%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%20%22%E6%AD%A3%E5%B8%B8%22%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E6%9C%80%E7%B5%82%E5%87%BA%E5%8A%9B%3A%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Eimx8mpevk%20%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%3A%3CBR%20%2F%3E%20imx8mpevk%20%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%3A%3CBR%20%2F%3E%20imx8mpevk%20%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%3A%20root%3C%2FP%3E%3CP%3E7%5Br%5B999%3B999H%5B6n8root%40imx8mpevk%3A~%23%20lsblk%3CBR%20%2F%3E%E5%90%8D%E7%A7%B0%20%E3%83%A1%E3%82%B8%E3%83%A3%E3%83%BC%3A%E6%9C%80%E5%B0%8F%20RM%20%E3%82%B5%E3%82%A4%E3%82%BA%20RO%20%E3%82%BF%E3%82%A4%E3%83%97%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3CBR%20%2F%3Emmcblk2%20179%3A0%200%207.3G%200%20%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%3CBR%20%2F%3E%7C-mmcblk2p1%20179%3A1%200%2083.2M%200%20%E3%83%91%E3%83%BC%E3%83%88%20%2Frun%2Fmedia%2Fboot-mmcblk2p1%3CBR%20%2F%3E%20%60-mmcblk2p2%20179%3A2%200%206.5G%200%20%E3%83%91%E3%83%BC%E3%83%88%20%2F%3CBR%20%2F%3E%20mmcblk2boot0%20179%3A32%200%204M%201%20%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%3CBR%20%2F%3Emmcblk2boot1%20179%3A64%200%204M%201%20%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%3CBR%20%2F%3E%3CSTRONG%3Emmcblk1%20179%3A96%200%2029.7G%200%20%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3ENXP%20i.MX%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%206.1-micledore%20imx8mpevk%20ttymxc1%3C%2FP%3E%3CP%3Eimx8mpevk%20%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%3A%3CBR%20%2F%3E%20imx8mpevk%20%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%3A%3CBR%20%2F%3E%20imx8mpevk%20%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%3A%20root%3CBR%20%2F%3E%207%5Br%5B999%3B999H%5B6n8root%40imx8mpevk%3A~%23%3CBR%20%2F%3E%20root%40imx8mpevk%3A~%23%3CBR%20%2F%3E%20root%40imx8mpevk%3A~%23%3CBR%20%2F%3E%20root%40imx8mpevk%3A~%23%3CBR%20%2F%3E%20root%40imx8mpevk%3A~%23%20lsblk%3CBR%20%2F%3E%E5%90%8D%E7%A7%B0%20%E3%83%A1%E3%82%B8%E3%83%A3%E3%83%BC%3A%E6%9C%80%E5%B0%8F%20RM%20%E3%82%B5%E3%82%A4%E3%82%BA%20RO%20%E3%82%BF%E3%82%A4%E3%83%97%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3CBR%20%2F%3Emmcblk2%20179%3A0%200%207.3G%200%20%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%3CBR%20%2F%3E%7C-mmcblk2p1%20179%3A1%200%2083.2M%200%20%E3%83%91%E3%83%BC%E3%83%88%20%2Frun%2Fmedia%2Fboot-mmcblk2p1%3CBR%20%2F%3E%20%60-mmcblk2p2%20179%3A2%200%206.5G%200%20%E3%83%91%E3%83%BC%E3%83%88%20%2F%3CBR%20%2F%3E%20mmcblk2boot0%20179%3A32%200%204M%201%20%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%3CBR%20%2F%3Emmcblk2boot1%20179%3A64%200%204M%201%20%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%3CBR%20%2F%3Emmcblk1%20179%3A96%200%2029.7G%200%20%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%3CBR%20%2F%3Eroot%40imx8mpevk%3A~%23%3CBR%20%2F%3E%20root%40imx8mpevk%3A~%23%3CBR%20%2F%3E%20root%40imx8mpevk%3A~%23%3CBR%20%2F%3E%20root%40imx8mpevk%3A~%23%20%5B%2053.204996%5D%20mmc1%3A%20%E3%82%AB%E3%83%BC%E3%83%89%20aaaa%20%E3%81%8C%E5%8F%96%E3%82%8A%E5%A4%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%2054.494632%5D%20mmc1%3A%20%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%B0%82%E7%94%A8%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E5%8F%AF%E8%83%BD%E3%81%A8%E3%81%BF%E3%81%AA%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%2054.507807%5D%20mmc1%3A%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20aaaa%20%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84%E9%AB%98%E9%80%9F%20SDHC%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%2054.514138%5D%20mmcblk1%3A%20mmc1%3Aaaaa%20SC32G%2029.7%20GiB%3CBR%20%2F%3E%20%5B%2054.579534%5D%20blk_print_req_error%3A%208%20%E3%81%A4%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%8C%E6%8A%91%E5%88%B6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%2054.579543%5D%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%200%20op%200x0%3A(READ)%20flags%200x0%20phys_seg%201%20prio%20class%202%3CBR%20%2F%3E%20%5B%2054.595988%5D%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%201%20%E6%93%8D%E4%BD%9C%200x0%3A(READ)%20%E3%83%95%E3%83%A9%E3%82%B0%200x0%20%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%201%20%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B9%202%3CBR%20%2F%3E%20%5B%2054.607164%5D%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%202%20%E6%93%8D%E4%BD%9C%200x0%3A(READ)%20%E3%83%95%E3%83%A9%E3%82%B0%200x0%20%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%201%20%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B9%202%3CBR%20%2F%3E%20%5B%2054.619385%5D%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E8%AB%96%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%200%E3%80%81%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%83%9A%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%2054.630133%5D%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%200%20op%200x0%3A(READ)%20flags%200x0%20phys_seg%201%20prio%20class%202%3CBR%20%2F%3E%20%5B%2054.641276%5D%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%201%20%E6%93%8D%E4%BD%9C%200x0%3A(READ)%20%E3%83%95%E3%83%A9%E3%82%B0%200x0%20%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%201%20%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B9%202%3CBR%20%2F%3E%20%5B%2054.652768%5D%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%202%20%E6%93%8D%E4%BD%9C%200x0%3A(READ)%20%E3%83%95%E3%83%A9%E3%82%B0%200x0%20%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%201%20%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B9%202%3CBR%20%2F%3E%20%5B%2054.666656%5D%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E8%AB%96%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%200%E3%80%81%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%83%9A%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%2054.673827%5D%20mmcblk1%3A%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B%2054.743395%5D%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%200%20op%200x0%3A(READ)%20%E3%83%95%E3%83%A9%E3%82%B0%200x80700%20%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%201%20%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B9%202%3CBR%20%2F%3E%20%5B%2054.754949%5D%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%201%20%E6%93%8D%E4%BD%9C%200x0%3A(READ)%20%E3%83%95%E3%83%A9%E3%82%B0%200x80700%20%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%201%20%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B9%202%3CBR%20%2F%3E%20%5B%2054.766631%5D%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%202%20%E6%93%8D%E4%BD%9C%200x0%3A(READ)%20%E3%83%95%E3%83%A9%E3%82%B0%200x80700%20%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%201%20%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B9%202%3CBR%20%2F%3E%20%5B%2054.780512%5D%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%200%20op%200x0%3A(READ)%20flags%200x0%20phys_seg%201%20prio%20class%202%3CBR%20%2F%3E%20%5B%2054.791210%5D%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E8%AB%96%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%200%E3%80%81%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%83%9A%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%2057.764836%5D%20mmc1%3A%20%E3%82%AB%E3%83%BC%E3%83%89%20aaaa%20%E3%81%8C%E5%89%8A%E9%99%A4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%2061.159580%5D%20kauditd_printk_skb%3A%208%20%E3%81%A4%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%8C%E6%8A%91%E5%88%B6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%2061.159590%5D%20%E7%9B%A3%E6%9F%BB%3A%20%E3%82%BF%E3%82%A4%E3%83%97%3D1334%20%E7%9B%A3%E6%9F%BB(1776550758.196%3A16)%3Aprog-id%3D10%20op%3DUNLOAD%3CBR%20%2F%3E%20%5B%2061.171847%5D%20%E7%9B%A3%E6%9F%BB%3A%20%E3%82%BF%E3%82%A4%E3%83%97%3D1334%20%E7%9B%A3%E6%9F%BB(1776550758.196%3A17)%3Aprog-id%3D9%20op%3DUNLOAD%3CBR%20%2F%3E%20%5B65.070760%5D%20mmc1%3A%20%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%B0%82%E7%94%A8%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E5%8F%AF%E8%83%BD%E3%81%A8%E3%81%BF%E3%81%AA%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%2065.084575%5D%20mmc1%3A%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20aaaa%20%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84%E9%AB%98%E9%80%9F%20SDHC%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%2065.102862%5D%20mmcblk1%3A%20mmc1%3Aaaaa%20SC32G%2029.7%20GiB%3CBR%20%2F%3E%20%5B%2065.171885%5D%20blk_print_req_error%3A%202%20%E3%81%A4%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%8C%E6%8A%91%E5%88%B6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%2065.171896%5D%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%200%20%E6%93%8D%E4%BD%9C%200x0%3A(READ)%20%E3%83%95%E3%83%A9%E3%82%B0%200x0%20%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%201%20%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B9%202%3CBR%20%2F%3E%20%5B%2065.188475%5D%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%201%20%E6%93%8D%E4%BD%9C%200x0%3A(READ)%20%E3%83%95%E3%83%A9%E3%82%B0%200x0%20%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%201%20%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B9%202%3CBR%20%2F%3E%20%5B%2065.199891%5D%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%202%20%E6%93%8D%E4%BD%9C%200x0%3A(READ)%20%E3%83%95%E3%83%A9%E3%82%B0%200x0%20%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%201%20%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B9%202%3CBR%20%2F%3E%20%5B65.212268%5D%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E8%AB%96%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%200%E3%80%81%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%83%9A%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%2065.223329%5D%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%200%20%E6%93%8D%E4%BD%9C%200x0%3A(READ)%20%E3%83%95%E3%83%A9%E3%82%B0%200x0%20%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%201%20%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B9%202%3CBR%20%2F%3E%20%5B%2065.234610%5D%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%201%20%E6%93%8D%E4%BD%9C%200x0%3A(READ)%20%E3%83%95%E3%83%A9%E3%82%B0%200x0%20%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%201%20%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B9%202%3CBR%20%2F%3E%20%5B%2065.245811%5D%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%202%20%E6%93%8D%E4%BD%9C%200x0%3A(READ)%20%E3%83%95%E3%83%A9%E3%82%B0%200x0%20%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%201%20%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B9%202%3CBR%20%2F%3E%20%5B65.258065%5D%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E8%AB%96%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%200%E3%80%81%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%83%9A%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B65.265245%5D%20mmcblk1%3A%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B%2065.339512%5D%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%200%20%E6%93%8D%E4%BD%9C%200x0%3A(READ)%20%E3%83%95%E3%83%A9%E3%82%B0%200x80700%20%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%201%20%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B9%202%3CBR%20%2F%3E%20%5B%2065.351038%5D%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%201%20%E6%93%8D%E4%BD%9C%200x0%3A(READ)%20%E3%83%95%E3%83%A9%E3%82%B0%200x80700%20%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%201%20%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B9%202%3CBR%20%2F%3E%20%5B%2065.362544%5D%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%202%20%E6%93%8D%E4%BD%9C%200x0%3A(READ)%20%E3%83%95%E3%83%A9%E3%82%B0%200x80700%20%E7%89%A9%E7%90%86%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%201%20%E5%84%AA%E5%85%88%E5%BA%A6%E3%82%AF%E3%83%A9%E3%82%B9%202%3CBR%20%2F%3E%20%5B%2065.376346%5D%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%200%20op%200x0%3A(READ)%20flags%200x0%20phys_seg%201%20prio%20class%202%3CBR%20%2F%3E%20%5B%2065.389118%5D%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20mmcblk1%E3%80%81%E8%AB%96%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%200%E3%80%81%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%83%9A%E3%83%BC%E3%82%B8%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20I%2FO%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E4%BB%B6%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%94%E5%8D%94%E5%8A%9B%E3%82%92%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2365862%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20SD%20CARD%20Detection%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2365862%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262664%22%20target%3D%22_blank%22%3E%40Rajendersamangula%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%85%83%E6%B0%97%E3%81%A7%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%8E%E9%80%9F%E6%99%82%E3%81%AE%E3%83%8F%E3%83%B3%E3%83%89%E3%82%B7%E3%82%A7%E3%82%A4%E3%82%AF%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A0%E3%81%8C%E3%80%81%E9%AB%98%E9%80%9F%E6%99%82%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A0%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%8A%B5%E6%8A%97%E5%99%A8R54%E3%81%A8R55%E3%81%AB%E9%83%A8%E5%93%81%E3%82%92%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%91%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%82%92%E8%A6%8B%E3%82%8B%E9%99%90%E3%82%8A%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AFDNP%EF%BC%88%E9%9D%9E%E5%AE%9A%E5%9E%8B%E9%83%A8%E5%93%81%EF%BC%89%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%AD%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E5%86%85%E3%81%AE%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E4%B8%8B%E3%81%92%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%9C%80%E5%BE%8C%E3%81%AB%E3%80%81pinctrl_usdhc2%20%E3%81%AE%E9%A7%86%E5%8B%95%E5%BC%B7%E5%BA%A6%E3%82%92%E4%B8%8A%E3%81%92%E3%80%81%E5%A4%96%E9%83%A8%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E6%8A%B5%E6%8A%97%E3%81%8C%E3%81%AA%E3%81%84%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E5%86%85%E9%83%A8%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E6%8A%B5%E6%8A%97%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81NVCC_SD2%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%97%E3%81%A6%E3%80%813.3V%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%83%A9%E3%82%B9%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2367821%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX8MP%20SD%20CARD%20Detection%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2367821%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%9E%E3%83%8C%E3%82%A8%E3%83%AB%E3%81%95%E3%82%93%E3%80%81%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%82%82%E5%90%8C%E3%81%98%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AB%E3%82%88%E3%82%8A%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%E3%83%A9%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E4%BB%98%E3%81%8D%E3%81%AESD%E3%82%AB%E3%83%BC%E3%83%89%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%82%A2%E3%82%A6%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81nvcc-sd2%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%ABPMIC%E3%81%8B%E3%82%89%E3%81%AESD%E3%82%AB%E3%83%BC%E3%83%89VSD_3V3%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E5%87%BA%E5%8A%9B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82dts%E3%81%A7%E3%81%AF%E3%80%81%E9%80%9F%E5%BA%A6%E3%82%92100MHz%E3%81%8B%E3%82%8925MHz%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%97%E3%80%81no-1-8-v%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FLINGO-BODY%3E
