IEC 60730 Library
IEC 60730 Library
841 次查看
pbaierlac
I have a few questions about the test library implementation.
For the data pinDir value in the digital IO setting what should the value for this be?  My assumption is that it would be 0 for input and 1 for output.  Is this correct?
For the pinMux I am not sure what to put in this value.  I am not multiplexing this pin so my assumption is that the value would be 0.  Is this correct?
For the clock and watch dog tests what are the values for the limits?  Are they just the clock ticks?
标记 (1)
0 回复数
