I’ve encountered a technical issue and require technical support to find a solution or an answer.
699 次查看
zhanxi
 Hello
During usage testing, this chip encountered the following issues.
Please take a look and provide a solution.
Below is the problem
1、0x400~0x407: 8-byte backdoor decryption key for the memory, used to temporarily decrypt the MCU when enabling backdoor decryption
2、0x408~0x40B: P-Flash protection (Protection) configuration bytes, whose values are automatically loaded by the hardware into the P-Flash protection register (FPTOTO~3) as their initial values during the MCU reset process; 0x40C: Flash encryption (Security) configuration byte, whose value is automatically loaded by the hardware into theP-Flash encryption register (FSEC) as its initial value during the MCU reset process
3、0x40D: Configuration byte for the non-volatile flash option, whose value is automatically loaded into the Flash Non-Volatile Option Register (FOPT) by the hardware during the MCU reset process as its initial value
4、0x40E: EEPROM protection configuration byte; its value is automatically loaded by the hardware into the EEPROM protection register (FEPROT) as its initial value during the MCU reset process
5、0x40F: D-Flash protection configuration byte; its value is automatically loaded by the hardware into the D-Flash during the MCU reset process
6、The Flash Protection Register (FDPROT) is set to its initial value
678 次查看
pavla_hajna
in order to assign your inquiry accordingly could you please specify the part number you refer to? Thank you. Have a nice day.
Pavla
%3CLINGO-SUB%20id%3D%22lingo-sub-2352282%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E6%8A%80%E6%9C%AF%E9%97%AE%E9%A2%98%EF%BC%8C%E9%9C%80%E8%A6%81%E6%8A%80%E6%9C%AF%E6%94%AF%E6%8C%81%E6%9D%A5%E6%89%BE%E5%88%B0%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E6%88%96%E7%AD%94%E6%A1%88%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2352282%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CFONT%3E%3CFONT%3E%3CFONT%3E%3CFONT%3E%E4%BD%A0%E5%A5%BD%3CBR%20%2F%3E%E5%9C%A8%E4%BD%BF%E7%94%A8%E6%B5%8B%E8%AF%95%E4%B8%AD%EF%BC%8C%E8%BF%99%E6%AC%BE%E8%8A%AF%E7%89%87%E9%81%87%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%E8%AF%B7%E6%9F%A5%E7%9C%8B%E5%B9%B6%E6%8F%90%E4%BE%9B%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%3E%3CFONT%3E%3CFONT%3E%3CFONT%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E9%97%AE%E9%A2%98%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3E%3CFONT%3E%3CFONT%3E%3CBR%20%2F%3E%201%E3%80%810x400~0x407%EF%BC%9A%E5%86%85%E5%AD%98%E7%9A%84%208%20%E5%AD%97%E8%8A%82%E5%90%8E%E9%97%A8%E8%A7%A3%E5%AF%86%E5%AF%86%E9%92%A5%EF%BC%8C%E7%94%A8%E4%BA%8E%E5%9C%A8%E5%90%AF%E7%94%A8%E5%90%8E%E9%97%A8%E8%A7%A3%E5%AF%86%E6%97%B6%E4%B8%B4%E6%97%B6%E8%A7%A3%E5%AF%86%20MCU%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%3E%3CFONT%3E%3CFONT%3E%3CFONT%3E2%E3%80%810x408~0x40B%EF%BC%9AP-Flash%20%E4%BF%9D%E6%8A%A4%EF%BC%88%E4%BF%9D%E6%8A%A4%EF%BC%89%E9%85%8D%E7%BD%AE%E5%AD%97%E8%8A%82%EF%BC%8C%E5%85%B6%E5%80%BC%E5%9C%A8%20MCU%20RESET%20%E8%BF%87%E7%A8%8B%E4%B8%AD%E4%BD%9C%E4%B8%BA%E5%88%9D%E5%A7%8B%E5%80%BC%E7%94%B1%E7%A1%AC%E4%BB%B6%E8%87%AA%E5%8A%A8%E5%8A%A0%E8%BD%BD%E5%88%B0%20P-Flash%20%E4%BF%9D%E6%8A%A4%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%88FPTOTO~3%EF%BC%89%EF%BC%9B0x40C%EF%BC%9A%E9%97%AA%E5%AD%98%E5%8A%A0%E5%AF%86%EF%BC%88%E5%AE%89%E5%85%A8%EF%BC%89%E9%85%8D%E7%BD%AE%E5%AD%97%E8%8A%82%EF%BC%8C%E5%85%B6%E5%80%BC%E5%9C%A8%20MCU%20RESET%20%E8%BF%87%E7%A8%8B%E4%B8%AD%E7%94%B1%E7%A1%AC%E4%BB%B6%E4%BD%9C%E4%B8%BA%E5%85%B6%E5%88%9D%E5%A7%8B%E5%80%BC%E8%87%AA%E5%8A%A8%E5%8A%A0%E8%BD%BD%E5%88%B0%20P-Flash%20%E5%8A%A0%E5%AF%86%E5%AF%84%E5%AD%98%E5%99%A8%20(FSEC)%20%E4%B8%AD%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%3E%3CFONT%3E%3CFONT%3E%3CFONT%3E%3CBR%20%2F%3E3%E3%80%810x40D%EF%BC%9A%E9%9D%9E%E6%98%93%E5%A4%B1%E6%80%A7%E9%97%AA%E5%AD%98%E9%80%89%E9%A1%B9%E7%9A%84%E9%85%8D%E7%BD%AE%E5%AD%97%E8%8A%82%EF%BC%8C%E5%85%B6%E5%80%BC%E5%9C%A8%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8RESET%E8%BF%87%E7%A8%8B%E4%B8%AD%E4%BD%9C%E4%B8%BA%E5%85%B6%E5%88%9D%E5%A7%8B%E5%80%BC%E7%94%B1%E7%A1%AC%E4%BB%B6%E8%87%AA%E5%8A%A8%E5%8A%A0%E8%BD%BD%E5%88%B0%E9%97%AA%E5%AD%98%E9%9D%9E%E6%98%93%E5%A4%B1%E6%80%A7%E9%80%89%E9%A1%B9%E5%AF%84%E5%AD%98%E5%99%A8%20(FOPT)%20%E4%B8%AD%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%3E%3CFONT%3E%3CFONT%3E%3CFONT%3E%3CBR%20%2F%3E4%E3%80%810x40E%EF%BC%9AEEPROM%20%E4%BF%9D%E6%8A%A4%E9%85%8D%E7%BD%AE%E5%AD%97%E8%8A%82%EF%BC%9B%E5%9C%A8%20MCU%20RESET%20%E8%BF%87%E7%A8%8B%E4%B8%AD%EF%BC%8C%E5%85%B6%E5%80%BC%E4%BD%9C%E4%B8%BA%E5%85%B6%E5%88%9D%E5%A7%8B%E5%80%BC%E7%94%B1%E7%A1%AC%E4%BB%B6%E8%87%AA%E5%8A%A8%E5%8A%A0%E8%BD%BD%E5%88%B0%20EEPROM%20%E4%BF%9D%E6%8A%A4%E5%AF%84%E5%AD%98%E5%99%A8%20(FEPROT)%20%E4%B8%AD%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%3E%3CFONT%3E%3CFONT%3E%3CFONT%3E5%E3%80%810x40F%EF%BC%9AD-Flash%20%E4%BF%9D%E6%8A%A4%E9%85%8D%E7%BD%AE%E5%AD%97%E8%8A%82%EF%BC%9B%E5%85%B6%E5%80%BC%E5%9C%A8%20MCU%20RESET%20%E8%BF%87%E7%A8%8B%E4%B8%AD%E7%94%B1%E7%A1%AC%E4%BB%B6%E8%87%AA%E5%8A%A8%E5%8A%A0%E8%BD%BD%E5%88%B0%20D-Flash%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%3E%3CFONT%3E%3CFONT%3E%3CFONT%3E%3CBR%20%2F%3E6%E3%80%81%E9%97%AA%E5%AD%98%E4%BF%9D%E6%8A%A4%E5%AF%84%E5%AD%98%E5%99%A8%20(FDPROT)%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E5%88%9D%E5%A7%8B%E5%80%BC%3CBR%20%2F%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2352357%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20I%E2%80%99ve%20encountered%20a%20technical%20issue%20and%20require%20technical%20support%20to%20find%20a%20solution%20or%20an%20answer%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2352357%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E4%B8%BA%E4%BA%86%E5%AF%B9%E6%82%A8%E7%9A%84%E8%AF%A2%E9%97%AE%E8%BF%9B%E8%A1%8C%E7%9B%B8%E5%BA%94%E7%9A%84%E5%88%86%E9%85%8D%EF%BC%8C%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E8%AF%B4%E6%98%8E%E6%82%A8%E6%89%80%E6%8C%87%E7%9A%84%E9%83%A8%E4%BB%B6%E7%BC%96%E5%8F%B7%EF%BC%9F%E8%B0%A2%E8%B0%A2%E3%80%82%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E5%B8%95%E5%A4%AB%E6%8B%89%3C%2FP%3E%3C%2FLINGO-BODY%3E
