How to play a simple audio file using NXP K66f?
1,207件の閲覧回数
pibew84514
Hi guys, I am a beginner doing a small project using the K66f board.
I am trying to implement this: once the PIR motion sensor detects something, it plays an audio.
And I have no clue how the audio works on this board. I looked at the examples provided by MCUXpresso and the code is just overwhelming.
Is there a simply way to achieve this? All I want is playing an audio file.
And do I have to use the SD card to get the audio file? Or it will be included in the solution?
Thanks for your help! https://kodi.software/ https://dltutuapp.com/tutuapp-download/
1,184件の閲覧回数
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, I reviewed your information and I suggest using the example from the demo application named SAI, the last part could help your application.
Pavel
