How to connect PCA9509
Yasoga
Is it possible to use PCA9509 side by side serially?
JozefKozon
Hi Yasumasa Ogawa,
I am not sure if serial connection of two PCA9509 is possible. The PCA9509 was not intended for such connection. Only way possible could be to connect the B ports together and I2C ICs on the A ports.
Could you please provide more details about your application? Perhaps we can offer you a better component for your application.
With Best Regards,
Jozef
Yasoga
To Jozef
thank you for your answer.
Insert the board into the subrack.
I2C communication between boards.
Since it passes through the backboard, I am thinking of mounting an I2C repeater on each board.
Best Regards
JozefKozon
Hi Yasumasa Ogawa,
Could you please draw a sketch about the connection?
With Best Regards,
Jozef
Yasoga
To Jozef
I will send you a sketch.
Best Regards
JozefKozon
Hi Yasumasa Ogawa,
I think it is possible to use our PCA9509 in the configuration you provided in the sketch.
With Best Regards,
Jozef
Yasoga
To Josef
relieved.
Best Regards
