High-Impedance Buffer
813件の閲覧回数
Jordan1x
Hi everyone,
I’m working on a small digital logic project and I’m considering using a 74HCT1G126GV as a buffer/line driver. The part is a single-channel buffer with 3-state output and a supply range of 2–5.5 V, so it’s ideal for mixed-voltage logic interfaces. The datasheet is here.
My plan is to place the 74HCT1G126 between a microcontroller output and a shared bus or external module. Because the output can be disabled (tri-state), I can avoid bus conflicts when multiple devices share the same lines. It’s also useful for isolating noisy parts of a circuit or for level shifting/helping drive loads that the MCU can’t handle directly.
Before I build, I have a few questions and I’d love your input:
Is it okay to rely on the 74HCT1G126’s 3-state behavior for shared-bus applications, or are there timing or leakage pitfalls I should watch out for? For mixed-voltage interfacing (e.g. 5 V logic driving 3.3 V), how reliable is the HCT buffer in real-life use? Any known gotchas regarding signal integrity or margins? When placing this buffer on a PCB, what layout practices would you recommend (trace routing, decoupling, pull-ups/pull-downs for high-Z)?
Thanks in advance!
タグ(1)
0 返答(返信)
%3CLINGO-SUB%20id%3D%22lingo-sub-2259495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%AB%98%E3%82%A4%E3%83%B3%E3%83%94%E3%83%BC%E3%83%80%E3%83%B3%E3%82%B9%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2259495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%9A%86%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E5%B0%8F%E8%A6%8F%E6%A8%A1%E3%81%AA%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%20%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%8A%E3%82%8A%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fwww.kasuo.com%2Fproduct%2F74hct1g126gv-125-datasheet-price-pdf-nxp-usa-inc%2F%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E74HCT1G126GV%20%E3%82%92%3C%2FA%3E%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%2F%E3%83%A9%E3%82%A4%E3%83%B3%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E9%83%A8%E5%93%81%E3%81%AF%E3%80%813%20%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%E5%87%BA%E5%8A%9B%E3%81%A8%202%20%EF%BD%9E%205.5%20V%20%E3%81%AE%E9%9B%BB%E6%BA%90%E7%AF%84%E5%9B%B2%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E6%B7%B7%E5%90%88%E9%9B%BB%E5%9C%A7%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AB%E6%9C%80%E9%81%A9%E3%81%A7%E3%81%99%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AF%E3%81%93%E3%81%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E8%A8%88%E7%94%BB%E3%81%AF%E3%80%8174HCT1G126%20%E3%82%92%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%A8%E5%85%B1%E6%9C%89%E3%83%90%E3%82%B9%E3%81%BE%E3%81%9F%E3%81%AF%E5%A4%96%E9%83%A8%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E9%96%93%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E5%87%BA%E5%8A%9B%E3%82%92%E7%84%A1%E5%8A%B9%20(%E3%83%88%E3%83%A9%E3%82%A4%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88)%20%E3%81%AB%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E8%A4%87%E6%95%B0%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E5%90%8C%E3%81%98%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E5%85%B1%E6%9C%89%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E3%83%90%E3%82%B9%E3%81%AE%E7%AB%B6%E5%90%88%E3%82%92%E5%9B%9E%E9%81%BF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E5%9B%9E%E8%B7%AF%E3%81%AE%E3%83%8E%E3%82%A4%E3%82%BA%E3%81%AE%E5%A4%9A%E3%81%84%E9%83%A8%E5%88%86%E3%82%92%E5%88%86%E9%9B%A2%E3%81%97%E3%81%9F%E3%82%8A%E3%80%81MCU%20%E3%81%8C%E7%9B%B4%E6%8E%A5%E5%87%A6%E7%90%86%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E8%B2%A0%E8%8D%B7%E3%81%AE%E3%83%AC%E3%83%99%E3%83%AB%E3%82%B7%E3%83%95%E3%83%88%E3%82%84%E9%A7%86%E5%8B%95%E3%82%92%E6%94%AF%E6%8F%B4%E3%81%97%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E3%82%82%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E7%9A%86%E3%81%95%E3%82%93%E3%81%AE%E6%84%8F%E8%A6%8B%E3%82%92%E8%81%9E%E3%81%8D%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%B1%E6%9C%89%E3%83%90%E3%82%B9%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%2074HCT1G126%20%E3%81%AE%203%20%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%E5%8B%95%E4%BD%9C%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%A6%E3%82%82%E5%A4%A7%E4%B8%88%E5%A4%AB%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%84%E3%83%AA%E3%83%BC%E3%82%AF%E3%81%AE%E8%90%BD%E3%81%A8%E3%81%97%E7%A9%B4%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E6%B7%B7%E5%90%88%E9%9B%BB%E5%9C%A7%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%EF%BC%88%E4%BE%8B%EF%BC%9A5%20V%20%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%81%A7%203.3%20V%20%E3%82%92%E9%A7%86%E5%8B%95%EF%BC%89%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6%20HCT%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E4%BF%A1%E9%A0%BC%E6%80%A7%E3%81%AF%E3%81%A9%E3%81%AE%E7%A8%8B%E5%BA%A6%E3%81%A7%E3%81%99%E3%81%8B%3F%E4%BF%A1%E5%8F%B7%E3%81%AE%E6%95%B4%E5%90%88%E6%80%A7%E3%82%84%E3%83%9E%E3%83%BC%E3%82%B8%E3%83%B3%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E6%97%A2%E7%9F%A5%E3%81%AE%E6%B3%A8%E6%84%8F%E7%82%B9%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%93%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%20PCB%20%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E6%89%8B%E6%B3%95%20(%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%80%81%E3%83%87%E3%82%AB%E3%83%83%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%80%81%E9%AB%98%20Z%20%E7%94%A8%E3%81%AE%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%2F%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3)%20%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
