Generate a tone
Generate a tone
1,593件の閲覧回数
Nadia
Good afgernoon,
I am quite new in this development environment, I work with a test board LPC54628.
My goal is to be able to generate a tone on a certain frequency, and I can´t find the way to do it, I've read some comments that talk about the use of FMT, but my board doesn't have that.
If someone could help me I would appreciate it, I can't find any library I could use in this development environment either.
Thank you very much, sorry for the inconvenience.
3 返答(返信)
1,575件の閲覧回数
vicentegomez
you can check the SCTimer sample code on the sdk for the LPC54628
you can download the SDK from the next link
https://mcuxpresso.nxp.com/en/select
I hope this will help you
Have a good day
1,557件の閲覧回数
Nadia
Hello, thank you very much for your answer.
But, with this you generate PWM signals, but would it also generate a tone?
1,524件の閲覧回数
vicentegomez
What kind of tone do you want to create?
With the PWM you can use different external part to generate a tone
Please let me know your comments
Have a good day.
