Generate a tone
Generate a tone
Nadia
Good afgernoon,
I am quite new in this development environment, I work with a test board LPC54628.
My goal is to be able to generate a tone on a certain frequency, and I can´t find the way to do it, I've read some comments that talk about the use of FMT, but my board doesn't have that.
If someone could help me I would appreciate it, I can't find any library I could use in this development environment either.
Thank you very much, sorry for the inconvenience.
vicentegomez
you can check the SCTimer sample code on the sdk for the LPC54628
you can download the SDK from the next link
https://mcuxpresso.nxp.com/en/select
I hope this will help you
Have a good day
Nadia
Hello, thank you very much for your answer.
But, with this you generate PWM signals, but would it also generate a tone?
vicentegomez
What kind of tone do you want to create?
With the PWM you can use different external part to generate a tone
Please let me know your comments
Have a good day.
