GUI-GUIDER installation problem in ububtu 24_04
1,244 次查看
nicomarconi
i team, i am having problem to install gui-guider in ubuntu 24_04,
dpkg: problemas de dependencias impiden la configuración de gui-guider:
gui-guider depende de libsdl2-dev; sin embargo:
El paquete `libsdl2-dev' no está instalado.
gui-guider depende de libvips42; sin embargo:
El paquete `libvips42' no está instalado.
gui-guider depende de cmake; sin embargo:
El paquete `cmake' no está instalado.
gui-guider depende de libffi7; sin embargo:
El paquete `libffi7' no está instalado.
gui-guider depende de gcc; sin embargo:
El paquete `gcc' no está instalado.
gui-guider depende de g++; sin embargo:
El paquete `g++' no está instalado.
Can you help me with some solution, please....thanks a lot
2 回复数
1,202 次查看
EdwinHz
Hi @nicomarconi,
Are you installing GUI Guider by running the following command?
sudo apt install ./Gui-Guider-Setup-1.9.1-GA-LIN.deb
If you run that command and are still getting dependency errors, try running the following first, and then try again:
sudo apt-get update
sudo apt-get upgrade
BR,
Edwin.
1,189 次查看
nicomarconi
Hi, good moorning, i have reinstalled the 22.04 Ubuntu version, and i thing gui-guider will work properly. I will let you know if it is working well . Thaks a lot for your help.
