Failure Modes in TJA1145A causing Bus Off
1,053 次查看
vipinrad
What are the physical layer failure modes in TJA1145A that could result in the node going to bus off state. I understand all below will affect comms but not necessarily trigger a bus of state. Any comments?
CAN-H/CAN L open
CAN-H/CAN L/both short to batt
CAN-H/CAN L/both short to gnd
CAN-H short to CAN-L
1,039 次查看
diazmarin09
Hello vipinrad,
I hope all is great with you. Thank you for using the NXP communities.
For further information about the CAN failures of the device, I do recommend reviewing the following application note.
https://community.nxp.com/pwmxy87654/attachments/pwmxy87654/other/9025/1/AH1309_v1_1_Application_Hin...
I hope this information helps.
David
