Hi All,
I made an nfc antenna for PN7150 with a design like the picture below. Performed testing obtained electromagnetic wave range of 1.34V. While the conditions that must be met is 6V. What do I need to change to meet these requirements?
Thank you,
Iwan
In order to better service for you. Would you please describe how to test "electromagnetic wave range of 1.34V" ?
Have a nice day.
sorry i am wrong, that's the value of the strength of the electromagnetic field not "electromagnetic wave range".
tested using ISO/IEC10373-6, where the value of Hmin must be greater than 6V.
I don't really understand this.
Thanks for your update information. For more information you can refer to the document as the link.
URL:https://www.nxp.com/docs/en/application-note/AN11755.pdf.
Have a nice day.
Thank you for your information. i will follow the document and inform you.
You are welcome.
Have a nice day.
