Hi everybody,
In my project, i have to program the CAN driver for µMPC5668G, i do this this by folowing several steps given in the datasheet(28.4.1 Transmit Process and 28.4.3 Receive Process) , and 28.5.1 FlexCAN Initialization Sequence.
i use FlexCan_A(CAN_A) module for both transmission and reception.
perhaps i miss somthing importante or i dont check something to track successsful transmission, or something else.
i have problem with the transmiting function,the problem is, when running my program(code warrior) the data avaible in the CAN bus changes, it gives frames that i dont put in my program !!!
does anyone had this bug ??
thank you for your help
Louiza :smileyhappy:
Solved! Go to Solution.
Hi Louiza,
Please refer to the https://community.freescale.com/thread/323209.
It should help and guide you to resolve your issues
Petr
Hi Louiza,
Petr
