Development Guideline for MIFARE Plus Card using Flutter
Matthew1971
May I know what tools/libraries should i use to develop a Flutter application to do the following
1. Data Encryption and Secure Authentication
2. Read data from Mifare plus s 2k rfid 1k card
3. Write data from Mifare plus s 2k rfid 1k card
My objective is to store only employee token
I need the application to support iOS and Android
Is this the following the right tool to use ?
https://github.com/okadan/flutter-nfc-manager
If not, can you pls suggest the right tool to use ? Is the Mifare card model selection correct ?
Pls advise. Thanks in advance
Matthew1971
jimmychan
We have no experience Flutter.
What we have is TapLinx. You may take it as reference.
TapLinx SDK for MIFARE, NTAG, ICODE and UCODE | NXP Semiconductors
Here is the developer Center. Inspire | NXP
Matthew1971
I found this site it has specific support for Mifare Plus:
https://github.com/nfcim/flutter_nfc_kit
Is this suitable or any suggestion ?
Matthew1971
Hi Jimmy,
What existing plugin or development kit you all currently have ?
I can't find Mifare Plus EV2 but ordered this card Mifare Plus S from Shopee for testing, what is the usage difference between Plus EV2 and Plus S ?
Shopee reference: https://shopee.com.my/13.56MHZ-(IC)-MIFARE-CUID-GEN2-GEN1-Mifare-Plus-S-2K-RFID-1K-S50-F08-FM1108-DU...
Is the above model selection suitable for storing only employee token usage ?
Thank you
jimmychan
Matthew1971
@jimmychan
Thank you for the helpful reference and the link to developer center.
Let me go through the user guide first
Matthew
jimmychan
There is no plugins for Flutter from NXP.
Jimmy
