Convert Analogue DC to SENT
1,283 次查看
sergiilevitov
Hi, we are looking for an AD Converter with 2 analogue inputs, to convert DC signal (5V max) to SENT protocol.
Can someone suggest any suitable solution?
1 回复
1,221 次查看
lisettelozano
Hello Sergii,
Unfortunately, we do not have a product that meets with your specifications.
We have the PCF8591 which is an 8-bit A/D and D/A converter with four analog inputs, one analog output, and a serial I2C-bus interface. You can check more details here https://www.nxp.com/products/analog/interfaces/ic-bus/ic-dacs-and-adcs/8-bit-a-d-and-d-a-converter:P...
I hope this information can be helpful.
Paulina
