Compulab UCM-iMX8M-Mini MIPI DSI clock
Giovanni1
Is it possible to change the Linux image on the Compulab UCM-iMX8M-Mini so that it is not dependent on the EEPROM and GPIO Expander and PCI clock on the Developement Kit of this SoM, for generating its MIPI DSI clock? The MIPI DSI clock is not generated if the EERPOM, GPIO Expander and PCI clock are taken away. Can this be changed? If so, how?
Bio_TICFSL
Yes its possible vie SDcard, maybe someone of Compulab can help you with that.
Giovanni1
Thank you Bio_TICFSL! I have contacted Compulab about this as well.
