Compatible FFC, FPC Connector Contacts for RK043FN02H-CT LCD
KHSALEH
Please advise part numbers for these connectors (PCB side).
kerryzhou
Hi @KHSALEH ,
  Do you want to know the RT1050-EVKB, or the RT1060-EVK related LCD connector, right?
  In the EVK board bom, it mentioned:
CON 1X40 + CON 1X6 + TFT DISPLAY
SUBASSEMBLY CON 1X40 FPC SMT RA + CON 1X6 FPC/FFC RA SKT + TFT DISPLAY 4.3INCH
You also can refer to the LCD spec:
https://www.nxp.com.cn/docs/en/supporting-information/RK043FN02H-CT.pdf
Whether this helps you?
kerry
