Code generation fails when tresos eclipse plugin's .mak file has been modified
1,325 次查看
eddy_bts
As title says,
Code generation fail with below error log when .mak file has been modified.
Any solution for resolving this?
1,320 次查看
cuongnguyenphu
Is there any change from your site to get this error? As the error said that module.mak fail in verify license.
I think you should uninstall then reinstall this package
标记 (1)
