Cannot taken branch to measure code coverage on S32R294
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
I am measure code coverage for some APIs relative ternary operator. Saw debugger cannot recognize branch when ternary operators are used and missing e_b also. It gives bad results measure code coverage. Please help me check it. My debugger as below:
- Function not taken decision:
- Funtion taken decision:
My code test as below:
/// typedefs to fix MISRA DIR4.6
typedef uint8_t BOOL;
#define TRUE ((uint8_t)1u)
#define FALSE ((uint8_t)0u)
typedef uint32_t FOO_ERRCODE;
#define FOO_ERR_NOERROR (0u)
#define FOO_ERR_INPUTOUTOFRANGE (0x50001u)
#define FOO_ERR_INPUTOUTOFRANGE_2 (0x1u)
uint8_t foo1(uint8_t input1);
BOOL foo2(BOOL input2);
FOO_ERRCODE foo3(uint32_t input3);
FOO_ERRCODE foo4(uint32_t input4);
FOO_ERRCODE foo5(float32_t SeqInterval);
uint8_t output1 = 0u;
output1 = (input1 == 1u) ? 0u : 1u;
return output1;
BOOL output2 = FALSE;
output2 = (input2 == TRUE) ? FALSE : TRUE;
return output2;
FOO_ERRCODE errodeCode = FOO_ERR_NOERROR;
errodeCode = (input3 > 32) ? FOO_ERR_NOERROR : FOO_ERR_INPUTOUTOFRANGE;
return errodeCode;
errodeCode = (input4 > 32) ? FOO_ERR_NOERROR : FOO_ERR_INPUTOUTOFRANGE_2;
return errodeCode;
uint64_t tmpSeqInterval;
tmpSeqInterval = (uint64_t)lroundf(SeqInterval * 1000.0f / 25.0f);
if ((tmpSeqInterval >= 1u) && (tmpSeqInterval < 0xFFFFFFFFu))
else
errodeCode = FOO_ERR_INPUTOUTOFRANGE;
return errodeCode;
void main(void)
foo1(1u);
foo1(0u);
foo2(TRUE);
foo2(FALSE);
foo3(35u);
foo3(25u);
foo4(35u);
foo4(25u);
foo5(10u);
foo5(0u);
foo5(0xFFFFFFFFu);
My tool and enviroment:
- Compiler Versions:
- SW Version:
- HW Version:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I am not sure what is the issue here.
Nor I see missing branch operation in your post. Is this issue with the translation or debugger processing?
Could you explain it in more detail?
Peter
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Peter,
In my driver have a lot of ternary operator are used, I am trying cover all ternary operator, almost them are taken 100% coverage report by TRACE32. Some ternary operator cannot taken, I sure I have unit test for cover them, but TRACE32 reported improper. Actually, I don't know root cause issue yet.
I checked assembly code by debug TRACE32. Saw ternary operator are not taken 100% coverage have not command "e_b". Checked in ternary operator taken 100%, saw all of them have command "e_b".
I guess TRACE32 need command ""e_b" to measure code coverage.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
what comes to my mind, is compiler translation.
Try to play with compiler optimizations, like no optimization at all , etc...
Debugger really displays only what is translated.
Also check output files form compilation to see if the translation corresponds with what you expect.
Peter
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
For questions about TRACE32 please contact Lauterbach at https://support.lauterbach.com/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Please write to Lauterbach again and include a link to this thread, so we can combine your requests.
Reinhard
