CST tool cannot open flash.bin
1,059 次查看
donjacobvellathottam
I've been trying to sign some images using mkimage tool and cst tool.
I've been following the documentation i found in github.
When I use the command : "./cst -i csf_uboot_atf.txt -o signed-u-boot-atf-container.img"
it shows the error : "[ERROR] CST: Cannot open flash.bin"
I'm stuck here now. Any idea why this is happening and how can I solve this
1 回复
1,034 次查看
Harvey021
From the error, check csf (csf_uboot_atf.txt) and the Binary file to be signed is in the correct path.
Harvey
