CLRC663 AckReq command
已解决
跳至解决方案
1,915 次查看
MIMIwho
Hello!
I want to know what is the CLRC663's AckReq command performs? Is it performs the ACKand Req_RN command in the ISO18000p3m3?
1 解答
1,907 次查看
KaiLi
Hello @MIMIwho
AckReq is a Query command, recommended you could try the following steps to operate your tag. These steps initializes the RC663 to the ISO 18000-3 mode 3 protocol, sends an inventory request and listens to the response of a tag:
1: Cancels previous executions and the state machine returns into IDLE mode
2: Flushes the FIFO and defines FIFO characteristics
3: Fills the FIFO with 0x0E and 0x0E. (0x00 ISO 18000-3 - 21 Protocol in rx/tx direction)
4: Executes LoadProtocol command with parameters 0x0E and 0x0E (FIFO). This translates to load protocol ISO/IEC 18000-3 mode 3 - 212
5: Flushes the FIFO and defines FIFO characteristics
6: Switches the RF filed ON.
7: Clears all bits in IRQ0
8: Switches the CRC extention OFF in tx direction
9: Switches the CRC extention OFF in rx direction
10: Only the 7 last bits will be sent via NFC
11: Fills the FIFO with 0x04 (Performs a Query command AckReq of ISO/IEC 18000-3 mode 3)
12: Executes Transceive routine
13: Waits until a tag has responded by checking the IRQ0 register
14: Reads bytes from the FIFO to get tag ack.
Thank you for your interest in NXP Semiconductor products andfor the opportunity to serve you.
Kelly
Technical Support
NXP Semiconductor
在原帖中查看解决方案
2 回复数
1,908 次查看
KaiLi
Hello @MIMIwho
Kelly
Technical Support
NXP Semiconductor
1,903 次查看
MIMIwho
Thank you so much
