CD1030 AMUX Channels
2,229 次查看
boxu
Special  AMUX channels of CD1030.
1) If I want  to get Battery Voltage,should I connnect  SG5 to Battery and get the 1/6 Value from AMUX output voltage.
2)If I want to get chip temp from AMUX, what's the relation ship of  AMUX output voltage with Physical Real Temperature. I can only get the Chip Temperature Sensor Coefficient is 8mv/degC from CD1030 Manual, but I don't know the offset.
1 回复
2,117 次查看
guoweisun
For your questions please see reply:
1: Yes,connect  AMUX  to ADC of MCU then read out the value(1/6 Vbat).
2: reply in your case.
