CAN Transceiver short mode
1,982 次查看
恵介松上
Hi, I am checking that our board is protected form short circuit.
We use TJA1043T(can transceiver).
Question 1.CANH & CANL are shorted during communication.
Does TJA1043's protection circuit operate?
Should we protect TJA1043 with software by detecting ERR_N?
If software protection is necessary, how many seconds will it break down in the shortest time?
Question 2.CANH & GND are shorted during communication.
Question 3.CANH & Vcc are shorted during communication.
Question 4.CANH is opened during communication.
Question 5.CANL & GND are shorted during communication.
Question 6.CANL & Vcc are shorted during communication.
Question 7.CANL is opened during communication.
If the shortest failure time is unknown, please answer other questions.
best regard.
标记 (2)
1,862 次查看
PetrS
the TJA1043 is only able to detect some kind of bus failures.
The bus failure diagnosis is discussed in AN1014 in chapter 6.6; http://www.nxp.com/documents/report/AH1014_v1_4_Application_Hints_TJA1042_43_48_51.pdf
Chapter 6.9 also gives you suggestion for the SW flow for handling failures.
BR, Petr
