CAN-Acknowledge-Error. Problem is known, but cannot fix it
rolande
Hallo, I'm using Phyboard-Mira and have a question considering the CAN-Bus. I'm transmitting ONE CAN-message via the CANCaseXL, but I receive ten times the same message at my board before CANoe aborts transmitting and displays an "Ack delimiter"- Error. So my question is how to tell the CAN-message-transmitter that the CAN-receiver has received the message? Normally the Ack-Bit is set to 0 from the receiving end automatically.
Is it maybe a problem that I have only one active participant on my CAN-Bus?
