Bitbake Gcc is getting stuck at do compile
sjane
Trying to do bitbake gcc / bitbake fsl-networking-full for Scarthgap on ubuntu 20.04. It is getting stuck at gcc do_compile. Any suggestions how to proceed.
with regards,
Sjane
Harvey021
Please share more details,
What the DISTRO/MACHINE you are building?
Which User guide you are following?
And share error log.
Harvey
hulk101
I have also encountered the same issue but with ubuntu 24.04.
Machine - S32G2-VNP-GLDBOX
Userguide - https://github.com/nxp-auto-linux/auto_yocto_bsp/tree/release/bsp38.0?tab=readme-ov-file
Error log:
ERROR: gcc-cross-aarch64-11.3.0-r0 do_compile: oe_runmake failed
ERROR: gcc-cross-aarch64-11.3.0-r0 do_compile: ExecutionError('/mnt/3231a06d-ea48-8393-9819fa8g54d6/S32G2/xen_build/BSP38/build_s32g274ardb2/tmp/work/x86_64-linux/gcc-cross-aarch64/11.3.0-r0/temp/run.do_compile.3892204', 1 , None, None)
