Application note MRFE6VS25LR5
2,581件の閲覧回数
sgazit
need application notes for LDMOS at freq around 200M to 400MHz
6 返答(返信)
2,538件の閲覧回数
sgazit
please advise if the MRFX035H is recommended for a new design
2,528件の閲覧回数
diazmarin09
Hello sgazit,
I am pleased to contact you again.
Unfortunately the MRFX035H device is not recommended for new designs.
Please accept my apologies.
David
2,499件の閲覧回数
sgazit
Thanks David for your reply. If both parts are not recommended for a new design and in order to summaries this request. It can be said that NXP doesn't have PA for ~25-35w to cover the freq band of 200-400MHz, correct?
Shlomi
2,492件の閲覧回数
diazmarin09
Hello sgazit,
Thank you for using the NXP communities.
Unfortunately, we do not have an active device within our 1-600 MHz – Broadcast and ISM portfolio. Please accept my apologies.
Have you considered a device from Active Antenna Systems portfolio?
David
2,540件の閲覧回数
sgazit
2,571件の閲覧回数
diazmarin09
Hello sgazit,
I hope all is great with you. Thank you for using the NXP communities.
Below is a link to the available documentation and useful material for further simulations:
MRFE6VS25L - 1.8-2000 MHz, 25 W, 50 V Wideband RF Power LDMOS Transistor
In addition to the documents mentioned above, we do not have any other documents.
Have you considered the reference design from the link below?
RF Circuit Collection
Note that the MRFE6VS25LR5 device is not recommended for new designs.
I hope this information helps.
David
