Application Note for machine to machine authentication of industrial devices using SE050
1,220件の閲覧回数
GarryFort
In the presentation titled "Factory Automation: NXP Security Solution", it mentions that there is a use case for machine to machine authentication of industrial devices using SE050. I could not find any application note for this use case. Could you please provide the link to the document if it exists?
Thank you,
Garry
1,211件の閲覧回数
Kan_Li
Hello @GarryFort ,
Please kindly refer to https://www.nxp.com/docs/en/application-note/AN12399-SE050_device_to_device_authentication.pdf for details.
Hope that helps,
Kan
