Any application note for MHT1003?
1,365 次查看
thiagogreboge
Greetings,
I would like to know if exists any application note for MHT1003NR3. In the component's datasheet (figure 5), there's a PCB layout and I would like to know if NXP developed some module to use the solution.
Thank you.
标记 (2)
1 回复
1,259 次查看
andrei_skok
Datasheet shows MHT1003NR3 Reference Circuit that was used for device specification.
Please look at the following link
http://www.nxp.com/assets/documents/data/en/fact-sheets/MHT31250CFS.pdf
This cooking module is still in alpha sampling stage only. Our beta units will be available in 2Q17.
Please contact our Distributors if you are interested in this module.
Andrei
