Airflow Operator for Alteryx
1,432 次查看
ursyathi
Has anyone written or knows the whereabouts of an Airflow Operator for Alteryx? Trying to automate the execution of an existing Alteryx workflow, typically executed manually. If this helps at all, both Airflow and Alteryx are behind the same firewall in an on-prem datacenter.
1 回复
1,425 次查看
LinaHou
Hello Ursyathi,
Unfortunately, I am not able to determine your request based on the information provided.
If feasible please elaborate on your request so that I can provide you a more accurate support.
Which NXP are you using now?
Pls provide the NXP part# and let me assign this case to our expert to help you more.
Look forward to your reply, thank you.
