Abuot PCF8563T Output Clock
2,567件の閲覧回数
bluestyle
hello,
   What is the rise time of PCF8563T,It works in the 32.768kHz? And what is the accuracy?
  Since I did not find the corresponding information in the Data Sheet, but  these parameters are quite important.
https://www.nxp.com/docs/en/data-sheet/PCF8563.pdf
Best  regards
タグ(1)
5 返答(返信)
2,467件の閲覧回数
guoweisun
For fosc accuracy is 0.2ppm,what is your point the 'rise time'?
2,467件の閲覧回数
bluestyle
posedge
2,467件の閲覧回数
guoweisun
So you also want to know the rise time of output clock,right?
2,467件の閲覧回数
bluestyle
   Yes, because the chip I used has requirements for the rise time of the clock.
2,467件の閲覧回数
guoweisun
This CLKOUT is open drain structure,the pull up resistor value will have an affect on rise time.
We don't have the detail information about it.
