Abuot PCF8563T Output Clock
bluestyle
hello,
   What is the rise time of PCF8563T,It works in the 32.768kHz? And what is the accuracy?
  Since I did not find the corresponding information in the Data Sheet, but  these parameters are quite important.
https://www.nxp.com/docs/en/data-sheet/PCF8563.pdf
Best  regards!
guoweisun
For fosc accuracy is 0.2ppm,what is your point the 'rise time'?
bluestyle
posedge
guoweisun
So you also want to know the rise time of output clock,right?
bluestyle
   Yes, because the chip I used has requirements for the rise time of the clock.
guoweisun
This CLKOUT is open drain structure,the pull up resistor value will have an affect on rise time.
We don't have the detail information about it.
