Abuot PCF8563T Output Clock
2,595 次查看
bluestyle
hello,
   What is the rise time of PCF8563T,It works in the 32.768kHz? And what is the accuracy?
  Since I did not find the corresponding information in the Data Sheet, but  these parameters are quite important.
https://www.nxp.com/docs/en/data-sheet/PCF8563.pdf
Best  regards!
标记 (1)
5 回复数
2,495 次查看
guoweisun
For fosc accuracy is 0.2ppm,what is your point the 'rise time'?
2,495 次查看
bluestyle
posedge
2,495 次查看
guoweisun
So you also want to know the rise time of output clock,right?
2,495 次查看
bluestyle
   Yes, because the chip I used has requirements for the rise time of the clock.
2,495 次查看
guoweisun
This CLKOUT is open drain structure,the pull up resistor value will have an affect on rise time.
We don't have the detail information about it.
