About MKV56F512 programed problem
1,275件の閲覧回数
gary_yang
Dear Sir:
Hello, we are a third-party programmer manufacturer. We used SWD communication to program the customer’s code successfully, but the customer was tested on board and found that the UART could not communicate
What could be the reason or what is recommended to check?
1,255件の閲覧回数
jingpan
Hi @gary_yang ,
Do you mean if you use your own programmer to download the UART example code in SDK, the example can't run well?
Jing
