A3M36SL039 Queries
A3M36SL039 Queries
1,303 次查看
moni_moni
Hi Team,
We are plan to use A3M36SL039  in our project. Please reply to below queries
1. We are using EM mode for setting DAC Voltage (Bias voltage).Since the register will be configured in digital value, what is the conversion formula to volt ?
2. If in EM, what are the initial values to be set in Sence_DACs.
3. The iC itself capable for thermal compensation. So is there any LUT available with temp vs gate bias voltage?
2 回复数
1,253 次查看
ErikaC
Hello
There is a GUI available on the web that can be used to set the DACs of the controller and read the temps.
https://www.nxp.com/webapp/Download?colCode=NXP-RF-INTEGRATED-MODULES-SETUP&appType=license
This GUI has the plot of voltage vs DAC setting.
Sense_DAC sets the reference voltage to compare to the VDS across the reference device.
Minimum typical value is 6'b001000 and maximum value is 6'b111111. Recommendation is that the value in this register be set higher than 6'b010000.
There is no LUT available. The temperature compensation is an analog feedback mechanism as shown in the data sheet.
The gain or slope of the compensation is set with the SENSE_DAC .
Here is the slop of the temp comp vs sense DAC setting.
1,262 次查看
ErikaC
I am working on your questions, I will let you know when I have the answer.
