9S08qd2 Development problem
751件の閲覧回数
nasim
I am using Code Warrior IDE version 6.3 (although help->about shows 5.9.0) and P&E Multilink BDM debugger .my problem is that when I Load the program it shows valid RAM address up-to 0x15f  were as the prm file has the allocation up-to 0xff. The controller registers are also not behaving normally.I think there is some problem with the header file for the controller.
Please advice
Nasim
0 返答(返信)
