74LVC1G17GS - prop delay question
1,200件の閲覧回数
paulschoenke
Hello!
The part overview for the 74LVC1G17GS claims that the part operates at 175 MHz, but the datasheet, specifies the Tpd (Propagation Delay) as a Max of ~7.0 nsec. If it operates at 175 MHz I would assume that the prop delay would be much less.
Can you confirm the specification on prop delay for this part?
Thanks again!
Paul
1,127件の閲覧回数
TomasVaverka
Hello Paul,
Thanks for your inquiry. This question is related to the Standard Products business. We would like to inform you that NXP has divested it´s Standard Products business on Feb 6th 2017. This new standalone company is called “Nexperia”, headquartered in the Netherlands, and is a world-class leader in Discretes, Logic and MOSFETs.
We would like to ask you to re-enter your inquiry at the Nexperia support web page: www.nexperia.com/support. Thank you!
Tomas
