UWB Secure Ranging (FIRALITE)
kuldeep
I need some help on secure ranging on SR150. I’m facing an issue when running Firalite secure ranging demo from UWBIOT_SR150_v04.02.01_MCUx. On debugging further I see a failure to select FIRALITE ADF,
The below call fails.
// initiator: select ADF LOG_I("initiator: select ADF");
se_status = Se_API_SelectADF(optsA, oid_entries, oid_entries_count, &selectAdfResponse);
ENSURE_OR_GO_EXIT(se_status == SE_STATUS_OK);
From readme for Firalite secure randing demo, below are the prerequisites
- SE051W should be connceted to host Refer :ref:`board-se051w`
- SR150 should be bound to SE051W. Refer :ref:`sr150-demo-binding`
- Perform the ADF provisioning Refer :ref:`firalite-adf-provisioning`
- Once ADF provisioning sucessful we can run the demo_fl_initator.
I was able to do the binding successfully. I could not find any information on firalite-adf-provisioning in SDK or in NXP site documentation. I suspect, The failure to select ADF is because of not doing firalite-adf-provisioning. Can you please help share the steps/demo code for firalite-adf-provisioning?
two_cloud
When performing operations based on firalite-adf-provising, I have the following questions:
1. How can I burn the se_VCOM firmware? Is it through DK6Programmer.exe?
2. After running the JRCPProxyConsole.exe -c COM44 command, no feedback is displayed in PowerShell.
3. The JCShell tool is not available.
Pierre0811
I have the same problem as Kuldeep; is there now a place where the information is accessible, or did we need to be contacted by NXP to solve this problem?
Ricardo_Zamora
Hi @kuldeep ,
Hope you are doing well. You will be contacted directly.
Have a nice day!
%3CLINGO-SUB%20id%3D%22lingo-sub-1602947%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUWB%20Secure%20Ranging%20(FIRALITE)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1602947%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20need%20some%20help%20on%20secure%20ranging%20on%20SR150.%20I%E2%80%99m%20facing%20an%20issue%20when%20running%20Firalite%20secure%20ranging%20demo%20from%20UWBIOT_SR150_v04.02.01_MCUx.%20On%20debugging%20further%20I%20see%20a%20failure%20to%20select%20FIRALITE%20ADF%2C%3C%2FP%3E%3CP%3EThe%20below%20call%20fails.%3C%2FP%3E%3CP%3E%2F%2F%20initiator%3A%20select%20ADF%20LOG_I(%22initiator%3A%20select%20ADF%22)%3B%3C%2FP%3E%3CP%3Ese_status%20%3D%20Se_API_SelectADF(optsA%2C%20oid_entries%2C%20oid_entries_count%2C%20%26amp%3BselectAdfResponse)%3B%3C%2FP%3E%3CP%3EENSURE_OR_GO_EXIT(se_status%20%3D%3D%20SE_STATUS_OK)%3B%3C%2FP%3E%3CP%3EFrom%20readme%20for%20Firalite%20secure%20randing%20demo%2C%20below%20are%20the%20prerequisites%3C%2FP%3E%3CP%3E-%20SE051W%20should%20be%20connceted%20to%20host%20Refer%20%3Aref%3A%60board-se051w%60%3C%2FP%3E%3CP%3E-%20SR150%20should%20be%20bound%20to%20SE051W.%20Refer%20%3Aref%3A%60sr150-demo-binding%60%3C%2FP%3E%3CP%3E-%20Perform%20the%20ADF%20provisioning%20Refer%20%3Aref%3A%60firalite-adf-provisioning%60%3C%2FP%3E%3CP%3E-%20Once%20ADF%20provisioning%20sucessful%20we%20can%20run%20the%20demo_fl_initator.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20was%20able%20to%20do%20the%20binding%20successfully.%20I%20could%20not%20find%20any%20information%20on%20firalite-adf-provisioning%20in%20SDK%20or%20in%20NXP%20site%20documentation.%20I%20suspect%2C%20The%20failure%20to%20select%20ADF%20is%20because%20of%20not%20doing%20firalite-adf-provisioning.%20Can%20you%20please%20help%20share%20the%20steps%2Fdemo%20code%20for%20firalite-adf-provisioning%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183004%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20UWB%20Secure%20Ranging%20(FIRALITE)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183004%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EI%20have%20the%20same%20problem%20as%20Kuldeep%3B%20is%20there%20now%20a%20place%20where%20the%20information%20is%20accessible%2C%20or%20did%20we%20need%20to%20be%20contacted%20by%20NXP%20to%20solve%20this%20problem%3F%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1604098%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20UWB%20Secure%20Ranging%20(FIRALITE)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1604098%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F207753%22%20target%3D%22_blank%22%3E%40kuldeep%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EHope%20you%20are%20doing%20well.%20You%20will%20be%20contacted%20directly.%3C%2FP%3E%0A%3CP%3EHave%20a%20nice%20day!%3C%2FP%3E%0A%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2344879%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20UWB%20Secure%20Ranging%20(FIRALITE)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2344879%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWhen%20performing%20operations%20based%20on%20firalite-adf-provising%2C%20I%20have%20the%20following%20questions%3A%3CBR%20%2F%3E1.%20How%20can%20I%20burn%20the%20se_VCOM%20firmware%3F%20Is%20it%20through%20DK6Programmer.exe%3F%3CBR%20%2F%3E2.%20After%20running%20the%20JRCPProxyConsole.exe%20-c%20COM44%20command%2C%20no%20feedback%20is%20displayed%20in%20PowerShell.%3C%2FP%3E%3CP%3E3.%20The%20JCShell%20tool%20is%20not%20available.%3C%2FP%3E%3C%2FLINGO-BODY%3E
