SR150 simultaneous Tag and Anchor mode
2,190件の閲覧回数
cbugk-dannie
I need to have ranging capability between multiple nodes of SR150 (using Murata Type2BP EVK). Is it possible to have this chip operating in both tag and anchor modes? I could not find such a demo, the only close match is multi-session Angle of Arrival (AoA) demo, which requires use of sessions. Thanks in advance.
タグ(4)
2 返答(返信)
2,170件の閲覧回数
Ricardo_Zamora
Hope you are doing well. Sorry for the inconvenience this might cause you but as the information of these products it's under NDA (Non-Disclosure Agreement) the information it's not public.
I apologize, but as you are using a module/kit from a Module Maker (MuRata), you would need to redirect your questions to them, as they should be supporting their kits.
I really apologize for the inconveniences this might cause you, but the support path for this is through the Module Makers.
Ricardo
2,108件の閲覧回数
cbugk-dannie
I understand, thanks for the redirection. Just to cover my base, trivial information on the question is listed within publicly available Getting Started PDF of the module.
