NXH3675 LE audio
NXH3675 LE audio
1,520 次查看
robrechtbisscho
How many audio channels in a single stream does the NXH3675 chip support?
Is the LC3 encoding done in sfotware or is a hardware encoder inside the chip use?
1 回复
1,510 次查看
Ricardo_Zamora
Hope you are doing well. NXH3675 and enablement (documentation, software and boards) are available for select customers with an approved NDA. Could you please contact your local sales representative or a Distributor from the Distributor Network | NXP Semiconductors?
Ricardo
