NCJ29D5D device reconnection problem
2,242件の閲覧回数
dingyazhou1
Hello, when I was debugging NCJ29D5D, I found that the anchor point and the key node could not be reconnected after the key node was powered on and off again. The anchor can be connected to the key node only after it is powered on and off again. It can't be reconnected even after sending a ranged Resume Command。
2 返答(返信)
2,238件の閲覧回数
dingyazhou1
The key node Ranging status is 0x2: Transaction Expired
2,229件の閲覧回数
Ricardo_Zamora
I'm really sorry for the inconvenience this might cause you, but as the information of the NCJ29D5D is under NDA (Non-Disclosure Agreement) the information of it it's not public.
Could you please contact the person that provided you the device for further support within this part?
I sent you a private message.
Ricardo
