DigitalKey Standard (CCC/ICCE/ICCOA)
Hyunjin1
According to the URL below, it is mentioned that DigitalKey of NXP supports CCC, ICCOA, and ICCE standards.
https://www.nxp.com/design/design-center/development-boards-and-designs/DIGITAL-KEY-RD
I have some questions regarding this:
1. If a phone supports two standards (CCC and ICCE) and the car only supports the CCC standard, how do the each devices match on which standard to use? When the car sends a Select Request to the phone, does the phone recognize CCC standard by checking something like the DigitalKey AID?
2. Is it impossible to use a phone that only supports ICCE with a car that only supports CCC? or If I install a separate CCC-supporting app on the phone, can I use it with the CCC car?
db16122
CCC is global standard while ICCE is local standard and it may not compatible with each other
%3CLINGO-SUB%20id%3D%22lingo-sub-2206797%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDigitalKey%20Standard%20(CCC%2FICCE%2FICCOA)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2206797%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAccording%20to%20the%20URL%20below%2C%20it%20is%20mentioned%20that%20DigitalKey%20of%20NXP%20supports%20CCC%2C%20ICCOA%2C%20and%20ICCE%20standards.%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FDIGITAL-KEY-RD%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FDIGITAL-KEY-RD%3C%2FA%3E%3CBR%20%2F%3EI%20have%20some%20questions%20regarding%20this%3A%3C%2FP%3E%3CP%3E1.%20If%20a%20phone%20supports%20two%20standards%20(CCC%20and%20ICCE)%20and%20the%20car%20only%20supports%20the%20CCC%20standard%2C%20how%20do%20the%20each%20devices%20match%20on%20which%20standard%20to%20use%3F%20When%20the%20car%20sends%20a%20Select%20Request%20to%20the%20phone%2C%20does%20the%20phone%20recognize%20CCC%20standard%20by%20checking%20something%20like%20the%20DigitalKey%20AID%3F%3C%2FP%3E%3CP%3E2.%20Is%20it%20impossible%20to%20use%20a%20phone%20that%20only%20supports%20ICCE%20with%20a%20car%20that%20only%20supports%20CCC%3F%20or%20If%20I%20install%20a%20separate%20CCC-supporting%20app%20on%20the%20phone%2C%20can%20I%20use%20it%20with%20the%20CCC%20car%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2206797%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAutomotive%20Smart%20Cards%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2384568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DigitalKey%20Standard%20(CCC%2FICCE%2FICCOA)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2384568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECCC%20is%20global%20standard%20while%20ICCE%20is%20local%20standard%20and%20it%20may%20not%20compatible%20with%20each%20other%3C%2FP%3E%3C%2FLINGO-BODY%3E
