first steps- OSBDMJB16
2,562 次查看
novi
Hi all,
I need a some help.
I am using USBDM JB16 -- http://www.wayengineer.com/index.php?main_page=product_info&products_id=289
USBDMJB16  not responding.
I purchased this debugger for an HCS08 based microcontroller project. I was planning on using an Windows XP SP2 system and CodeWarrior 6.3 for MCU ,BDM firmware v2.0 or v4.5
This is my first attempt to use HCS08 back ground debug my experience is with HC08.
Am I missing something?
does the flash program .s19 in the my new USBDM JB16 mikrokontroler ?
Any help would be appreciated.
Thank you
regards
标记 (2)
4 回复数
2,280 次查看
novi
ok,
Tnx
regards
2,280 次查看
novi
Mickey:
When I buy OSBDM with processor HC908JB16, is it empy and I have to firmware  or it has software?
How I can check it has firmware?
2,280 次查看
pgo
Senior Contributor V
Dear Novi,
The JB16 version of USBDM is really obsolete.
However, you can still try the current firmware etc with it.
I suggest you download the USBDM software and install it.  You will also need to update the firmware.
Documentation:
http://usbdm.sourceforge.net/
Software/Drivers/Firmware:
http://sourceforge.net/projects/usbdm/files/Version%204.9/
Good luck!
bye
2,280 次查看
Mickey
The first must go first, "http://www.wayengineer.com" If they do not have a good after-sales service, and that cheap is useless.
