USBDM HCS08DZ60 Flash Dump Problem
m4rvell
Hello
I'm trying to read processor with USBM but I have a problems with doing it. Could someone please help me to set up flash dump program because I don't know what is the Page Register Adress and I'm unable to find it in datasheet.
I've tried several times to make a dump of the memory but after making dump and write it back to the mcu the device was not responding, so i assume that I didn't get accurate full dump of the memory. I wrote flash and eeprom adresses from datasheet to Memory Dump program, I've tried to read the memory with 1,2 and 4 Width lenght but without luck.
I will be gratefull for Your advices.
