I'm sorry if this is a forum for Coldfire and my post is related to Kinetis, but I couldn't find a better place to write.
I'm using a Windows XP virtual machine running with VmWare Player where I installed latest P&E Micro drivers for OSBDM (downloaded from www.pemicro.com). I installed the same drivers also on the host system (Windows 7).
When I connect TWR-K60N512 through a USB cable, the host system detects it correctly. I try to connect the OSBDM device to the virual machine, but it doesn't work. In the peripheral list I see only Jungo/Windriver node.
Any suggestion?
