Can't connect. The Debugger can not connect to the P&E device(HC/RS/S12Z GDI Protocol Adapter)
1,135件の閲覧回数
andy_Musk
2 返答(返信)
1,005件の閲覧回数
pgo
Senior Contributor V
Hi Andy,
Can you identify the programmer you are using a bit more clearly?
OSBDM programmer supported by P&E is only used in some development boards (e.g. https://www.pemicro.com/osbdm/osbdm_description.cfm)  There is an earlier version that is not supported - I don't know why they used the same name!
Also many of the OSBDM interfaces currently available are actually USBDM.
A picture may clarify the situation.
bye
1,134件の閲覧回数
andy_Musk
i am use CW11.1 and OSBDM programmer to program a  board base on MC9S08JM60CLD chip.  but i cannot success it,why?
