I got my service package for MC9S12G but however there's no connction option for TBDML?
解決済! 解決策の投稿を見る。
Hi Jinhy,
Codewarrior not longer supports using TBDML with newer targets. It has been replace by the JM60-based OSBDM (Open Source BDM).
You can follow the procedure given at the bottom of the following page to manually add the missing information:
If you are using USBDM (rather that the original TBDML) software then it will be necessary to re-install USBDM to have it do the updates automatically.
bye
The above is after installation of USBDM.
Hi Jinhy,
bye
