Motor Control Class: Hall Sensors Initial Position
In this video we enhance a Simulink model to allow the reading of hall sensors after processor reset to get the initial position of the rotor.
We discuss about:
- How to build a special initialization routine to read the halls once in the beginning
- How to use StateFlow programming
- How to mix the direct read of GPIOs with ISR based on hall transition readings
NOTE: Chinese viewers can watch the video on YOUKU using this link
注意:中国观众可以使用此链接观看YOUKU上的视频
100%が役に立ったと言っています (1/1)
バージョン履歴
最終更新日:
‎06-11-2017 10:12 PM
更新者:
